1080p USB powered monitor.
11 Jun 2003
Sheffield, UK
My missus has started to appreciate my second screen in the office (so I've started loosing it as I DID mount it for my/spare machines use on an arm, my bad :p ).
She's generally laptop though. Thinking with the right monitor I can probably find/make a suitable mount to hang it off the top of the existing screen so she's got something for when she's chilling in bed with it (likes to WoW on one screen with a movie on the other :p ).
So... after a cheap screen that only needs to be plugged in via USB for simple display stuff.
Seen a good few, most are in the £120+ range, something a BIT cheaper would be golden. What can folks suggest?
