1080ti and Nvidia Surround
22 Jul 2012
UK
I've just upgraded from an R9 290 which I used in an Eyefinity 3 x monitor set up. I'm trying to figure out an easy way to use Nvidia Surround.
I've now got the card/monitors in my sig - connected via displayport/minidisplayport.
I've set up Surround with bezel correction etc., but is there a simple way of turning Surround on/off?
When I go back from Surround to 3 individual monitors only 1 is active and I need to reset my display settings.
I've set up the three key shortcut in Nvidia settings but it doesn't seem to work.
I've got the DisplayFusion software, but I don't want to use that if there's a simple way of toggling between surround and 3 separate monitors.
It seems a constant query re. Surround based on a google search.
