1080Ti Core voltage unlock
6 May 2009
In MSI Afterburner, is it possible to unlock Core voltage (mV) control?
In general I have selected 'Unlock voltage control' but it still shows nothing and no slider
GPUZ reports 1.0620V under load
Thanks
I can't remember the version of afterburner I run which enables voltage control on the 1080ti, but when I get home later this evening I'll let you know.
Thanks - I upgraded to 4.4.2 and it has the voltage slider. Doesn't seem to make any difference at all as per my 980Ti!
The voltage slider alone isn't enough, you'll need to use a manual boost curve if you want to make use of the extra voltage.
Open afterburner and hit ctrl+f. If you look at voltage along the bottom, and then at the curve up until where it flatlines. That's the point of where the clock and voltage will boost to. If you want to add more voltage, you need to adjust the points beyond this.
