Hi, I built a new system around a month ago. A 1950x, 32GB with 2 Asus ROG Strix 1080Ti OC Edition cards in SLI. I’ve got a SeaSonic PSU 1000W Titanium Prime - I also have a line interactive UPS. Both GPUs make a whining noise when the fans hit certainly levels, it’s definitely coming from airflow not coil whine - it’s not very high pitch and it happens when I manually regulate fan speed or when it does it automatically. I thought it could be a vibration of the GPU shroud or some other item in the case, but it’s not. As both cards produce the same noise at similar levels I assume it is the card design itself. I purchased both cards a few weeks apart from different sellers (both new). Does anyone have experience of these cards? The airflow noise is fine it’s just the whine which can oscillate up and down which is a real pain...
Thanks
Thanks
