I have a 1080ti that consumes around 72W idle according to GPU-Z. Load is 0%, voltage 0.762v, GPU clock 1468 vram clock 1377 (seems high).
Windows Power plan set to "Power Saver", Nvidia control panel power management mode set to "Optimal Power".
If I switch the second monitor off, the clocks drop down to 177/101 and it uses about 23W which is what I expect.
Is there anyway to fix this behaviour so it downclocks properly when both monitors are switched on?
