1080ti hybrid overclock
28 Feb 2011
Norwich
Hey guys im currently playing battlefront 2 and i was wondering what a good safe overclock for my evga sc2 1080ti hybrid is?
In msi afterburner xxx
Typically max power allowed, +100 on core and +400 on memory.
You should be able to go beyond those points, but that's a good start.
As always, go up in smaller increments just to be sure.
xxx ;)
Or, if you find very minimal gains from overclocking your 1080Ti, like I have to be honest, have a play with undervolting and a custom core 'curve' in Afterburner to see just how cool you can get it to run whilst still being overclocked a bit.
That's what I'm experimenting with on my new 1080Ti that I've custom AIO watercooled now. Currently at 1925 (could go higher, need to test) on the core with only 1.00 volts max. Tested in benchmarks to check all is well and performing as it would at those clocks with full power (1.06 volts for FE card), and it is, so I consider it amazing I can run this card using less power, even lower temps, and still getting good overclocks. Great cards!
As we're doing it XXX ;)
