1080ti memory speed question
10 Aug 2005
Sorry if this is a nooby question but i'm a bit confused.
The gpu I have (EVGA SC2) is advertised as having a memory speed of 11010Mhz, yet GPU-Z is showing the memory as 1376Mhz and Heaven benchmark is showing it as 5585Mhz?
These figures are all wildly different!
It is actually running at 2752mhz.
GPU-Z 1376 x 2 = 2752mhz
Advertised speed 11010/4 = 2752mhz
And heaven 4 often gets it wrong by a few MHz 5585/2 = 2768mhz
More detailed explanation.
GDDR5X can run in to modes, double data rate and quad data rate mode. GDDR5 only has double data rate mode.
So GDDR5X is really clocked X2 for double data rate and then X2 again for quad data rate.
2752 x 2 = 5504 x 2 = 11008
Since DDR3, ram also has double the data lines which is why in GPU-Z you are seeing 1376 as that is showing the speed of 1 data line even though there are 2.
So 1376 x2 = 2752 x 2 = 5504 x 2 = 11008.
Hope that makes sense.
