1080Ti Noise
9 Dec 2006
@ManCave
Hey all
since release of the 1080Ti i have had one of these
AORUS GeForce® GTX 1080 Ti 11G
https://www.gigabyte.com/us/Graphics-Card/GV-N108TAORUS-11GD#kf
The temperatures/noise have never been great but acceptable,
average between 70c-74c @ 1440/4K with 1500rpm on likes of Sleeping dogs GTA etc
however lately the card is getting louder and temperatures have average rose to 73-78C with 2500rpm! its also pulling 325W
I've cleaned the card out and not much at all dust in their.
the card has 3 bequiet 120MM gently blowing cool air on to it at 500RPM
i'm considering what to replace this card with as i want a quiet system
(current loudest thing is my water pump..)
what are your thoughts? 1080ti/2080ti? 2080?
game at 1080p/1440p & 4K
current spec you need to be aware of
2950x @ 4.4 (PBO)
32GB 3133Mhz @ 13-13-13-32-75
1000W titanium seasonic ultra prime
lian li o11 dynamic
Rest of the pc is silent git my Threadripper at 40c in games like bf4 on only 400rpm fans.
It's just 1080 getting hot./ noisy
If you have water-cooling can you not get a block for it and add it to the system? If not then I would try reapplying the TIM as has been said. It'll give you a good reson to strip the card and give it a good clean and hopefully will sort it.
It's winter now so temps should have gone down over the last few months not up..
