1080ti overclocking
16 Feb 2004
London
what's the avg overclocks for 1080ti's? I've brought a 2nd hand evga 1080 ti sc2 and just trying it out.
I'm looping unigine valley benchmark in window mode 1440p max settings and using msi afterburner
current settings
votlage: 100%
temp limit: 84c (stock)
core: +100 (avg ~1980, min 1930, max 2010)
memory: +400 (5900mhz)
temp: 70c
fan: 70%
I can see minor artifacts at +500 memory or 6000mhz
+130 core crashes unigine
All pascals boost to similar frequencies. You just pay for a different cooler.
2,000 is about average, perhaps boosting 2100 and the odd few hitting 2150.
Raise temp target to max, if you look in the monitor charts you’ll probably see it’s holding back a little occasionally. That said without more cooling (water) it’s probably around the limit - you can most likely get higher core by dialling the memory back to about +200 or 0.
is it best to push for core or memory OC with these cards?
I had to back it off a little last night in games, will keep testing tonight to find a stable OC
