1080ti with two DVI-D monitors, no output on second monitor (in windows)
4 Feb 2011
Nottingham
Upgraded from a Titan to a 1080ti, which only has a single DVI-D output. I have two older monitors which are both 1440p but only have a DVI-D input.
The second monitor is currently connected via a DP to DVI-D lead (I'm aware this limits me to 1080p output), I've also tried connecting it via HDMI to DVI-D with the same results. It turns on and takes primary status when booting, but as soon as windows initiates the login screen, it switches back to the main DVI-D to DVI-D display.
If I check the secondary screens status in windows, all of the options are greyed out. If I then try to alter the 'Multiple Display' options on the main screen from 'Show only 1', it gives me the error: "Display settings could not be saved. Please try a different combination of settings." I've tried lowering the res on the main display to various lower resolutions, to no avail.
I've also updated the GPU drivers to the latest version.
It clearly seems like a windows issue. Anyone got any ideas?
