10900k @5.8GHZ
4 Dec 2021
UK
Hi All,
So I'm currently running my 10900k @ 5.4GHZ all core Vcore set a 1.430 in the bios Cache 5.2GHZ. I'm using TVB and it boosts to 5.6GHZ fully stable. Now, If I set 5.6GHZ all core in the bios the required vcore is ridiculous 1.5 @ LLC 6, but my CPU will boost 5.8GHZ on a few cores. However, in a more realistic scenario, I would like to set my cores to per core usage. When I do this, I set 5.8GHZ to 2 cores, 5.7GHZ to 3 cores, 5.6GHZ to 4 cores, and 5.5GHZ 5 cores, then 5.4GHZ 10 cores. However, when I set it this way it wont boot into windows. Any ideas why it boost when setting the OC to TB boost table 2, but not when I set it per core usage?
