10Gb networking - modules needed as well as cables?
20 Feb 2011
Just for fun I thought I’d buy a SFP+ fibre cable to hook up a Ubiquiti switch to my Aoostar NAS. Both have 10Gb fibre ports so I assumed all I needed was a cable. Having it ordered the cable, I decided to do some research (I know, I know!!) and it seems I’ll need corresponding modules to slot into the ports before I can fit the cable. Is this correct? The reason I ask is that cable fitments look as if they’ll go straight into the 10Gb ports.
Cable arrived today, plugged straight into the switch and eventually plugged straight into the Aoostar once I figured out it went in upside down compared to the switch… 10Gbps of unnecessary network speed now on tap for a £10(ish) cable. Nice!
