A few months back I was looking at swapping the 182 for something more economical as I will have a 25 mile commute each way to work come October. This may change but one thing is for sure is that I can't manage it every day in that car up and down the A41. The road isn't great and it's generally very bumpy and there's quite a bit of road noise. The consumption doesn't bother me a great deal but more the fact that it's not a great place to be, bearable but not brilliant.
The 182 is great fun on the odd occasion that I give it a bit of beans which isn't actually all that often. I'll have a sports bike soon as well which will feed my need for speed.
I think something different is definitely on the cards. I've driven a works diesel Focus estate which was a total **** box with absolutely zero go but I wasn't expecting great things from it anyway. Some may remember I had the chance to drive a few higher range diesels (A6, 9.3, C class, all 11 plate) however these are way way out of my budget though I did find driving them was fine though they obviously respond differently to a petrol engine.
My 182 should fetch between £3500-£4000, higher end at a push, so I could most likely increase my budget to nearer the £5k mark though the less the better.
My needs & wants:
Comfortable
Reasonable to good economy
Reliability
Something that looks smart/tidy/sporty
I'm sure you're all frantically typing 'Mondeo ST220!!!111one!1', which I am aware of and some higher mileage options are in budget. Though what are the other contenders?
My budget could increase if needs be but not by a great deal and only if it would find me a tidier example. E46 320d's seem fulfill my criteria.
Any other options to be looking at?
BennyC
My needs & wants:
Comfortable
Reliability
BennyC
though did get on to a dual carriage way briefly. I wouldn't want to drop £15-16k and end up having to settle for one that's a bit rough or isn't as nicely spec'd as I'd like. So I've been going around in circles with budget and also car. Warranty too on E60/E90's are a bit too expensive for me...
