http://www.youtube.com/watch?v=SZcxS2pQiM0
+ lightning heel n toe
+ isnt that lap time the same as the new Nissan GTR? lol
skip the first 4 mins![]()
before going down each cog, to match the rpm with road speed.
i see
but why not just change down later when your road speed is less?
It's because it aids breaking.i see
because you're using engine braking.
i see
why would you want to let the rpm fall when on a time attack lap?
the blip on the throttle increases the rpm of the engine so it matches the road speed.
if the rpm of the engine is too low, the engine breaks the car
so if you want to change to 3rd at 40 mph and your revs are at 2k, then the engine will break, so you blip the throttle, so that the rpm is higher to stop the engine slowing the car
but if you change to 3rd when you are going slower, 30mph then your engine being at 2k rpm will not slow the car at all.
that's what i meant
or do i have something confused here?
oh sorry you want the engine to help break...
but won't the engine break you more if it's spinning at lower rpm?
If you slow down more in 4th, when you shift to 3rd there is still an rpm difference which needs to be overcome on the downshift, only it is smaller when at low rpm, you can get away with it on low speed downshifts by slipping the clutch and it gives a smooth transition but it wears out your clutch.but if you change to 3rd when you are going slower, 30mph then your engine being at 2k rpm will not slow the car at all.
No, because turning the engine over at high revs requires more power, therefore when you're not putting that power in (throttle) there's more retardation... but don't lower revs break you more?
good idea.
okay, don't laugh, but, when he's breaking and changing down gears, why does he blip the throttle after going down each cog?
Impressive driving
