10th Gen Intel CPU Water Cooler AIO
The LGA 1200 for 10th gen socket uses same plate / layout as LGA1151 / previous gen. Means pretty much every cooler which works fine on LGA1151 will work fine. Can confirm yourself by checking respecting manufacture page to confirm it works. Off the bat, can see NZXT, Fractal define, Corsair etc all updated material on there sites for the coolers to say LGA 1200 socket is supported fine.
I'm glad you have asked this question as I've just bought a 10th gen setup and only have a old hyper 212 to use till I get my water cooling loop done with a old EK supermey evo.
