11400 integrated graphics no signal issue?
21 May 2018
South Wales
Just built my daughters PC with a 11400.
Entered the BIOS first boot, saved settings and now getting no signal with diagnostic led on VGA.
If I clear CMOS I can get into BIOS again, but as soon as I leave and restart save settings or not I get no post?
She doesn’t have a discrete card only IGPU, can any one help?
No worries, used a butt load of B560 boards, and all the Gigabyte ones have been nothing but hassle tbh.
I have another questions? Installed all drivers etc, however upon checking the device manager I have 4 devices without drivers. 2 PCI Devices, SM Bus Controller and Unknown Device... Any ideas?
Sounds like motherboard chipset drivers.
Look on the support website and download.
Plus, does the board have onboard devices you are not using, Bluetooth, onboard audio etc.
Chipset driver needs installing.
Yes and are in use and functioning perfectly, I have the updated drivers but still displaying the obvious.
AMD drivers aren't going to help with an Intel system. :p
Getting the feeling ASUS or Intel may have forgotten some drivers? It's an ASUS B560 TUF Plus WiFi motherboard. Download everything required and still showing 4 devices? Perhaps something in the BIOS maybe needs turning off, perhaps not needed?
Windows up to date ?
Did you install the intel display driver?
All drivers are currently up-to-date. Everything working accordingly however, if i disable the onboard WiFi and Bluetooth the SM Bus Controller and a PCI Device. Switch onboard WiFi and Bluetooth back on and these reappear. This still leaves an unknown device and PCI Device remaining even when I disabled onboard WiFi and Bluetooth. Something tells me either Intel or ASUS are missing drivers in the installation packages?
