116 bsod when using SLI
10 Sep 2010
Cornwall, England
Hello
I've recently upgraded to a SB system but have kept my GPU's
When I run SLI I get a bsod with a error code 0x00000116, Both cards work fine on their own , neither exceed 39C under load.
Strange thing is that It will run furmark in SLI fine, but nothing else.
Any ideas guys?
Thanks.
Sounds like a similiar problem that i had when i changed from ati to nvidia and overclocked the card. My problem was not enough voltage either to the cpu or the gpu. Turns out it was the gpu and cpu undervolting, upped the voltages and ran Heaven benchmark passed a few loops without crashing.
Have you tried upping the voltages on both cards or tried running lower clocks?
Hey thanks you were right
Although I'm still confussed, both cards were at stock before, the cards I have come factory overclocked so I underclocked them to stock GTX570 speeds and inputted the stock voltage for the cards (1.05V) and it ran unigene heaven fine, I then tried the factory overclock speeds and that also ran fine. I'm now running slightly overclocked, still with stock voltage.
Still a mistery to me, but its working now. Thanks
