1180 PCB breakdown
No, it's not confirmed as anything, thus still a rumour. Although a lot points to it being legitimate. Not all that interesting till we see the final product, IMO. The fingers alone point to it most likely being a prototype.
lol, its the final PCB. hence, NOT a rumour.
Poor upgrade if you're on a 1080ti but we knew that already, even if you're nuts about performance per watt it doesn't look much different on this initial analysis.
Seems unlikely given that it's got an NVLink (as seen on Quadro GV100 / GP100) rather than SLI connector
I take that back - it's a mirror image of the NVLink connector (likely to stop professionals buying "cheap" bridges for use with Quadro/Tesla cards vs the "proper" £360+ ones)
Analysis based on almost nothing :D
I honestly thing the Graphics section has outdone itself this time around. Congratulations :D
The bottom PCB is for a GTX1080TI.
Looking at the size of the GPU pads,this looks smaller than than the GP102 in the GTX1080TI,so is under 471MM2.
I estimate around 400MM2 to 420MM2 in size,just comparing relative sizes(roughly).
Interestingly the GM204 in the GTX980 was around 398MM2.
