11900k cooler to replace Noctua DH-15
18 Feb 2004
Lincolnshire
I have an 11900k and temps are in the 75s with no oc running 3d mark for instance.
If i enable intel adaptive boost to high performance in the bios, (5.1ghz) I then hit 100 dgerees and the cpu throttles which in turn gives worse results on the benchmark and permformance in games.
Ive reseated the cooler a few times with new paste and the results are always the same, i also see some others with the same issue with this cooler.
So what will cool the beast so i can use it to its full potential as such.
I have a fractal design meshify so the cooler would need to fit into this which i can hopefully check.
I presume an all in 1 water cooler would work better? but im out of the loop as to what is good and enough for this cpu.
Many thanks in advance.
Its a Meshify C.
Ive seen others say it cant cool the 11900k as well.
You can fit a 360mm aio in the front but you need to check witch, maybe its a case of manually tweaking your settings to find the balance.
Google meshify c 360mm aio check out some build logs.
