I am in the middle of a new build and have finally got to the stage of turning it on and installing the OS. I'm using a Lian-Li DK-Q2 case which has a total of 12 case fans and therein lies my problem.
My motherboard is a Gigabyte Z170X Gaming 7 which has three system fan headers. "No problem!" I thought and I bought three Akasa FLEXA FP5S PWM cables which split one sys fan header out into five separate plugs and are powered by a SATA connection from the PSU. The problem is they don't seem to want to work! The fans come on and stay on at 100% regardless of any settings I change in the BIOS. I have also downloaded Speedfan which doesn't seem to detect any fans at all. I also tried Gigabyte's own Windows app and setting the fans to the "Silent" preset had no effect. I'm now looking at some kind of different solution. Can you guys recommend me a fan controller which will be capable of running 12 fans in this config:
4x Corsair ML120 Pros grouped as rear intake fans (Power draw of 0.3A each)
8x Akasa AK-FN058 Apache Blacks grouped into 4 on the left and 4 on the right side of the case pushing air out through two 480mm rads (Power draw of 0.33A each)
Another issue is that my case has no 5.25 drive bays which I could slot a controller head unit into so it would have to be some other solution, but I have no experience whatsoever with fan controllers so I could use a little insight from you guys!
