£1200 build
15 Aug 2003
Essex
Hi All.
Trying to get a build around 1200ish (can push a bit)
Things I don't want budge on
S340 Elite NZXT
M2 Drive (Primary OS so 128GB is fine)
Nvidia Gfx (have a gsync Mon)
Need everything except keyboard, mouse and monitor.
Primary use is gaming at 1440P.
Thanks!
My basket at Overclockers UK:
Total: £1,324.89
(includes shipping: £14.10)
Do you have other storage drives already?
Could go for a cheaper lesser quality M.2 like the Intel 600P.
650W not necessary but price is right on that one.
A cheaper case would get you a better cooler or a 1TB HDD if you need one.
Ryzen 5 CPUs coming out in a couple weeks if you're willing to wait and compare.
If it's Windows 10 you can activate a digital license for it, and it should transfer to the new motherboard no problem. Other Windows versions may involve a call to Microsoft (and tell them you've replaced the motherboard). 10 would be best going into the future though, as new platforms won't be supported much longer with older versions.
