£1200 - Home Machine for Editing, VM, Some Gaming
Man of Honour
16 Jul 2009
Edinburgh
Budget: £1200 give or take, needs to include the PC Build / components only (no peripherals or monitor needed at this point)
What the main uses of the PC will be: For mobile use I’ve gravitated toward tablet device (iPad Pro) and have just been using RDP back into my laptop at home if I need something on the desktop.
Really want this so I can remote back into it when I’m away for running Photoediting and Design Apps in the rare event my iPad doesn’t do what I need!!
Mainly things like Photoshop and Lightroom with possibly some Dev/Virtual Machine work as well.
On the gaming front I like to play CPU intensive things like Civilzation and wouldn’t mind being able to play the latest games although I tend to use the Xbox One X for gaming.
Probably also use for media streaming but I don’t imagine that will be an overhead on what’s already been specced for the rest.
The spec of your current PC and whether you are re-using any parts from it. N/A
The native resolution of your monitor. Currently using a 24” 1080P screen but might look at upgrading to a 4K screen for my photography at some point - not massively important for gaming though.
Whether you will be overclocking or not. Happy to overclock, suspect I won’t need it for most things I’m planning on using the machine for.
How much storage space you require. 1TB+ possibly have an SSD for running OS/Programs and an HD/Hybrid (or SSD) for storage.
Do you have any special requirements? Wouldn’t mind a fairly small machine, doesn’t need to be tiny but certainly don’t need a huge thing!1
