The next time you use that emoticon I may suspend you.
Uh, ok, sorry? Is it against the rules or something? But yeah, I believe dual 290s are fine on 850W so three should be fine on 1200
Oh, I thought you guys were friends and he was joking with you....
Yeah it's not so much three 290's that concerns me. Run fine with a clocked 4790.
But I know the 3960x are power gobblers, so wasn't sure if that would push it over the edge...
I would think it still should be enough with a 3960X, roughly speaking the GPUs will draw about 950W and the 3960 I doubt will take over 350W, so you should be fine![]()
No more as it looks totally spammy and is in every post from you as you said last night you've over used it.
Who is this aimed at?![]()
When I used to mine Scrypt algo my rig would pull 1250w at the wall, All 3 290's were oc'd heavily but that 1250w figure is with almost 0 CPU use in the mix.
When you say oced heavily, can you give an indication of how much?
Doesn't sound promising though.
Probably going end up 3960x and dual gpu, or...
Try a different z97 board, and keep triple gpu...
When I was testing, at stock 947/1250 it draw around 900 watts, The OC's really upped the power usage a lot.
