Hi,
I have just purchased from OC 3 Samsung S23a700D 3d monitors to run on eyefinity but I am having problems getting them all to use 120hz.
I have tested each monitor and each DVI cable in every permitation in the 2 ports on GFX card and or the powered displayport and they will all run 120hz in fact if I plug any 2 in any order they will run 120hz but as soon as the 3rd one is connected I can only select 60hz.
In the catalyst control "My digital flat panels" option in "properties" I can select panel 1 and see its "Max reported refresh rate is 120hz panel 2 is 120hz but panel 3 is 60hz. I have tried everything to get all 3 in 120hz but cant crack it.
Resolution has not effect so if set it to 1920x1080 or 5760x1080 its still the same. All drivers are up to date. Also dont worry about the 3d aspect I am not using it but it does work fine when tested but will take so getting used to so I shelved that for now.
My setup
Quad core Q8300
AMD HIS HD6900 gfx card
Startech Mini DisplayPort to DVI Dual-Link Active Adapter – USB Powered
8GB Ram
Windows 7 64bit Ultimate
My setup
Quad core Q8300
8GB Ram
