So I bought a S23A700D off here a few years ago, it is a lovely monitor, which sadly I rarely use the 3d function but would love to use the 120hz.
I have always run it at 60hz simply because i was lazy.
Now I have a triple monitor setup and have been playing with settings I have tried to use 120hz.
I can select 120hz as an option if I use a DVI-D Dual link cable but it gives me really blurry text.
The card is an XFX 5770 XXX edition, with 2x DVI DP HDMI. I have the S23A700D and it has only HDMI and DVI.
I think my HDMI cables are 1.3a so it will only do 60hz, but the DVI shows 120hz as maximum.
I have used 2 different cables both DVI-D Dual link. (full pins and 1 - pin)
I get no signal for a few seconds then it appears but it looks awful.
Anyone got a clue what I'm doing wrong? I'm trying to dig out an XFX manual for a 5770 to see if both ports are DVI-D (they have the full pins but that doesnt help)
