120mhz problem :( on 770 gtx
Permabanned
8 Dec 2008
East yorkshire near hull
Hello i am looking for a fix to my problem.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-047-KF
I bought this card a month or so ago and i not been able to get the 3d /120 mhz working due to lack of dvi port.
I got in contact with the makers of the card but they not got back to me. Also ocuk dont seem to have a clue.
this is the cable i think my do the job.
http://www.overclockers.co.uk/showproduct.php?prodid=CB-062-AK
However i would have to use the adptor thing i got with the card and i am worried it wont have the required bandwidth to support the cable.
The adptor is a mini hd to hdmi.
So far i have tried a display port cable to hdmi.
A standard hdmi cable (using the adaptor)
And lasty using the adaptor then plugging in a hdmi to dvi adaptor into that then using a normal dvi cable i know supports 120mhz none of which worked :(
So as you can see had a bit of a ball ache with this and i really hope some one can help before i waste more money on cables that don't work :(
Ah crap :( thats what i was worried about
It says the card is 3d vision ready though and for 3d to work you need to have 120mhz
I really miss my 120mhz :(
I am pretty sure you can get something for this but the ones which specifically state full HDCP compatibility are not usually cheap.
You will need a DP to DVI-D DUAL link adapter.
The important part is the "Dual". You can get also get DVI-I dual link adapters so it can get confusing.
My monitor only supports hdmi and dvi :(
Would i need something like this :(
http://www.overclockers.co.uk/showproduct.php?prodid=GX-000-SR&groupid=1929&catid=1757
Looking around for display port to dvi but theres not a lot of info on them :(
Found this please say it will work ! lol
High-performance DisplayPort male to DVI-D dual-link male cable.
Pure copper conductors, gold-plated connectors and shielding from EM and RF interference.
Offers two-way display connectivity and optional audio support.
Higher performance than dual-link DVI at 10.8Gbps.
Supports a minimum resolution of 1080P at 24bpp, 50/60Hz.
Supports greater than QXGA (2048 x 1536) resolution at 24-bit colour depths.
Supports the 1Mbps bidirectional auxiliary channel.
Supports 8-bit / 10-bit deep colour.
DisplayPort V1.1 compliant.
Connectivity : DisplayPort male connector to DVI-D dual-link male connector
Length : 2.05m (6’ 8”)
Colour : Black
