- 10 May 2007
Hi Guys
Need some advise on case fans, I have a coolermaster cm-690.
To go with the 3 fans that came with it i also purchases 3 of the following
Yate Loon D12SH
http://www.overclockers.co.uk/showproduct.php?prodid=FG-002-YL&groupid=701&catid=57&subcat=4
Admitingly they do create much more airflow that the standard ones, but they are just so blinking noisy.
Can someone recomend me a 120 mm fan which is better than the standard ones (CM -690 standard 1200rpm) yet still keeps a relitively low noise level.
Thanks in advance (also ones that come with screws would be helpful!)
Yate Loon D12SH
