- 13 Sep 2005
- Crewe,Cheshire
Need a little advice with settings or maybe you could suggest something else I need to buy, finished my build yesterday and the only thing im still stuck with is slowing down my fans. Ive fit 4 x Apache there set up in a P182 antec case, 1 x intake at front, 1 exhaust on the top and 2 in a push/pull set up on a H50 cooler.
I purchased a Akasa AK-CB002 PWM Fan Splitter Cable from Oc thinking it would enable me to contol the 3 fans at the top of the case via the mobo cpu fan, so ramping up as and when needed under the mobo control. But as it is i can tell for sure its not doing this the cpu fan setting is showing as 1400rpm constant. I did notice that only one of the 3 fan connectors seemed to have 4 pins the other two 2 were missing one of the centre pins. The forth fan is plugged directly into the mobo on system fan 2.
Having checked my mobo (gigabyte GA-EX58) settings i have cpu smart fan [Enabled] and cpu smart fan mode [Auto] with the other options being voltage and PWM. I have tried PWM 50% i think it was but really dont understand that setting
After playing games all night last night the cpu never went above 55c spending most of its time at 38-45c even when gaming.
.After playing games all night last night the cpu never went above 55c spending most of its time at 38-45c even when gaming.
