My housemate has a shuttle SN45G and has bought a 80 to 120mm fan adapter and a 120mm fan to fit on the back to replace the 80mm fan so that the system which is a heavily overclocked Athlon 1700 DLT3C will be quieter in his bedroom. He set it up the other day and the system was quite unstable with higher temps than usual, we suspect it is because the fan wasnt pulling enough air through the shuttle ICE.
I know others have done this mod and was wondering if anyone else came accross this problem and how you solved it. Help much appreciated.
