I need to replace my fans on my rads. they do push a lot of air but i run them fair low RPM for quietness
So I need something that can push a decent amount of air at low RPM and be very effiicient, also I plan on doing push and pull configuration to ensure the air flow is good going into the case as the rads are front mounted.
Noctua AF12x25 is unfortunately out of my budget, can't justify spending £100 on fans.
what are the alternatives? I have been looking at Corsair ML series - reason, one of the existing fan's bearing seems to be going as it is clicking.
compared with £22 for a pair of ML fans
