120mm fan recommendations?
XIGMATEK XLF-F1253 Case fan - 120 mm
Around £7 each, OcUK don't sell them so I cant link you.
61 CFM, 1500rpm.
I have 3 in my case.
I also have those Xigmatek fans, 3 of them on my rad, and they are great.
I have mine hooked up to my fan controller and running at 800rpm they are fairly silent.
The xigmatek mentioned is very good, I have one in my case. Also consider AC Ryan Blackfire4 fans. I have several of those running in my case. They're all LED and they look great. They come in a multitude of different colours and push 77.70cfm @2000rpm. They're not loud either. You can find them quite easily and they're cheap, the last two I bought were about £3 each. Check my pics on this page, you can see the ac ryans, and the xigmatek at the back as exhaust.
http://forums.overclockers.co.uk/showthread.php?t=17185358&page=103
