120mm Fan Spacer
22 Aug 2010
On the Wagon-East Angular
Allo all. I've been putting my new build together, but have found a small snag. The side of the rear 120mm fan is covered by part of the case and I want to see that side of the fan. Is there a spacer easily available? Wants to be maybe 10/15mm thick. I've had a search but can't seem to find what I'm after - maybe I'm searching for the wrong term?
Any ideas welcome - ta
Etsy 3D printed spacers would be a good option.
Or maybe stack some 120mm fan vibration pads or even use the outer casing from an old fan though maybe a bit thick.
If money is tight get a old fan and take the blade and housing off, I've done this with some 140mm ones.
