120mm fan?
30 Jul 2005
Midlands
hi all, i currently got a side intake fan which is an akasa amber 12cm job. thing is today i put on a dust filter on the fan to stop the dust from clogging up in the system. as you can guess this filter has hurt the fans airflow a bit.
to compensate for the loss of airflow i was thinking of getting a new fan. question is, which fan is able to push more cfm than the akasa amber fan without being much louder?
nexus, panaflo or papst you say. which would be the best out of the lot?
the akasa i currently have is rated at 18db and 44cfm.
what would the others do?
I think you'll find this useful.
Edit: When companies advertise noise levels, it can be quite misleading as some take readings closer than others so it would appear to be louder.
