120mm fan
22 Mar 2008
Can anyone recommend a powerful 120mm fan that I can also turn down using my fan controller at night to be near silent? Need to shift some air :)
Hi mate,
In my opinion Antec Tricool make the best 120mm fans, they have a 3 spped selector and they move more air than any other fan I've witness and they look cool as well with a choice of red, green, blue leds.
if you search for Antec 900 case on utube then u can see the case empty with just the fans and it shows them on each speed and you can actually hear the difference
To be used as 1 intake and also another for out take. Was goign to get deltas but read they are too powerful for a fan controller
What's the controller? Or its channel wattage rating.
There's a Silverstone FM122 high CFM fan that comes with its own rheostat if the controller is a problem. For a case fan the Sharkoon 2000 Silent Eagle (GolfBall) is a medium that moves quite a lot of air for the noise, only 0.18A/2.16W.
The controller can handle 1A per channel and a 107CFM Delta WFB1212HE uses about 0.6A iirc, so that one would be ok. The Delta monster 190CFM FFB1212EHE 120x38mm would use 2A and kill it dead.
