120mm fan
3 Jan 2010
Hailsham
how good is this fan, anyone use these?
heres the stats as oc dont stock them, i'll have to get them from the states
think the colour will work really well with the case im building
Cooler Master 120mm x 120mm SUF-S12-EP UV Silent Fan, 3 & 4 Pin
# Features: High-transparency
# Bright and colorful under UV light
# Soft power cable, easier to organize
# Ultra Silent 22 dBA
Specifications:
# Fan Dimension : 120x120x25mm
# Voltage (Volt) : 12 VDC
# Current (Ampere) : 0.05 A
# Input Power (Watt) : 0.60 W
# Speed (R.P.M.) : 1220 R.P.M.
# Air Flow (CFM) : 42.73 CFM
# Air Pressure (mmH2O) : 1.56 mmH2O
# Noise (dB-A) : 22 dB-A
# Weight : 120 g
# Life (hour) : 30,000 hours
# Bearing Type : Sleeve
# Speed Senser : Yes
I will be using 3 to cool the case and two on the cpu cooler
The airflow to noise rating is rather good, I have some fans with around the same air flow but sound like a Jet.
There isn't much of a huge difference between getting these fans and any other within the same category, so looks good.
If you like them, buy them... Sleeve Type Bearings too, should be nice and quet and last a long time even on full RPM.
I personally think that UV is tacky. Also those fans are a little loud, my 1200rpm fans are around 15dB. I'd recommend some enermax fans for the case fans, and some vipers for the cpu cooler :)
