120mm fans
w3bbo said:
Yate loons are quiet and have decent cfm. They also have a blue led variant.
Also known as Nexus fans (slightly different cfm and noise levels, but made by the same people). I have 3 in my case and they are the best.
ASH1982 said:
How about these, true not blue led but the spec seems brilliant?
weescott said:
Also, don't trust manufacturers rated specs.
Go by reviews if you can find them.... SPCR have some good ones on fans.
Means you dont get stung by manufactures that quote specs with noise @ 5V, and CFM @ 12V!
I would say the xilence are quiet, i've used a 120mm before and i'm currently modding a case which i'll be putting 2 * 120mm and 2*92mm in. I think they're better than the ambers.
I'm currently using an Xilence 120mm fan as an intake over my GPU in my Antec Nine Hundred and the fan itself seems silent (unless I hold it in my hand and have my ear right next to it)
If you're going for blue LED fans, do me a favour and don't get Antec adjustable ones, even on "Low" setting they're audible, and they're not the most powerful of fans on the market unless you're happy with the sound of a wind tunnel coming out of your rig with the damn things on "High" :p
Banjo ;_;
