120mm fans
10 Mar 2009
these will be cooling a quad radiator
im looking to get 4 Scythe fans but am unsure on what to get.
I will be using a fan controller, so when im not straining the pc i want them quiet so will just turn them down. But when im playing high end games maxed out or benchmarking I want to be able to crank these things up and not really caring how much noise they make as long as its not utterly ridiculous but dont need it to be silent at max speed thats for sure. They must be 25mm wide max.
So what do you recommend?
Was looking at these http://www.overclockers.co.uk/showproduct.php?prodid=FG-022-SY first at they had an impressive CFM but maybe im missing something.
Or should i go for http://www.overclockers.co.uk/showproduct.php?prodid=FG-016-SY&groupid=701&catid=57&subcat=4
I've got 3 Noctua 120mm's in my case, and totally silent. The only noisy fans in ym setup are the graphics cards.
I just want to point out that the OP wants performance over Silence. The 110CFM looks good on the Slip-Streams mate. I would go for them
