Just one of them, the female side. The other one is just for another molex powered device so the molex plug doesn't get wasted on the fan. Molex is pretty hard to slot in, you just have to keep trying with brute strength.
Yup, it's the one on the right.
Give it a wiggle and press the tabs on the sides of the connector from the PSU to make it easier.
Glad to hear it all worked out, molex pins on fans tend to be fairly badly made in my experience. They are hardly ever aligned right, so a little wiggling and pushing is needed as you have found.
