- 3 Mar 2009
So for a long time, i was using a case which came with a 2 way splitter for the front and rear 120mm fans, in which i basically had very quiet chassis fans. Recently i changed cases, and didnt use the splitter this time, so i plugged the 120mm fans in (1 on the motherboards 4 pin chassis fan bit, and the other on a 3 pin), and while the front fan is quiet like on the previous case, the rear fan goes full whack and is pretty damn noisy.
From what ive read, this is normal, the motherboard doesnt slow the fans down, they just go full whack, and hence why im now hearing the noise level this high. I have 2 of these -
http://www.overclockers.co.uk/showproduct.php?prodid=FG-002-XG&groupid=701&catid=57&subcat=4
The rear 1 in the case runs at full whack and is quite noisy. Ive seen things like voltage reducers that would slow it down, but are there fans to buy that dont full at such high RPM's by design ? Would rather have a fan thats max RPM is slower than this to keep noise levels down without the need for any further wires/adapters etc. Any recommendations ? Anyone else had this in the past ?
