Hi got a rad here a TFC 120mm i gather it's an Xchanger model?
As has an ovalish circle with a large sort of X in the middle and circle has two direction pointers in it.
It's 60mm measured across casing and has a bleed/drain screw on other end to fittings M3 fixings.
What are they like? as thinking of fixing to rear 120mm fan on outside of case with fan on inside bolted through panel and adding it into loop with 360
