120mm radiator (push - pull)
18 Oct 2011
Where do I get long enough screws to attach the pull fan? As the 120mm rad already comes with one fan attached.
I will be fitting SP120's to the radiator (38mm deep without the fan (64mm with)
OCuk is selling some XSPC screws in packs of 4.
Just check and make sure they are the same tpe as other ones. M3 or 6-32.
If you are fitting SP120's they will come with the screws you need that RAD looks just like my H80i RAD and I have 2 x SP120's fitted in push pull.
I'm sure I only got the 3 rings, low noise adapter and standard self tapping short screws in my sp120 performance double packs. I've already linked to the xspc screws in the first reply to the op.
If you take a screw from your h100 and try it. If it's the same thread those xspc screws are what you need.
