1280x1024 res problem with BF2 - odd one ?
Man of Honour
16 Mar 2005
Clevedon , Bristol
Have just installed BF2, after asking here updated to 1.41 patch to get 1280x1024 res.
When i run at 1280x1024 the screen disappears/offsets approx. 25mm to the left. ( i.e 25mm of the graphic is missing on the left side and a blank/black space is on the right ).
A screen grab shows the full graphics ( no cut off ).
If i run at 1024x768 there is no problem.
I've tried on both monitors with the same result.
Has anyone else had this or can anyone offer any advice ?
( Gainward 24pipe agp 7800gs+ / Drivers 91.47 )
:confused:
Mark
DaveyD said:
Are you using DVI or VGA? As Macabre said, can you manually adjust it?
DVI to VGA on both monitors.
If i adjust it wont that affect all screen ( i.e windows desktop ) settings though ?
:o :o :o
Thanks for the advice, i hang my head in shame .
After changing my graphics card recently my monitors were set to 60 hertz, have changed them both to 76 hertz and everthings fine.
I am a tool :D
Cheers,
Mark
