12GB installed, 64-bit OS, only 4GB usable
30 May 2009
Maidenhead
Hey guys,
I have an issue with my PC. Specs in sig.
Windows 8 64-bit bit is saying on 4 GB is available of 12GB installed. RAM is showing up fine in CPU-Z.
Any ideas? Thanks
Sorry about the size
too tight a cpu cooler,or bent cpu socket pins can cause that
test with one ram stick and test one ram slot at a time,you need to find which slots arnt booting,then repeat the test with the other ram sticks just incase any sticks are faulty
did you test the same slot with a working stick? if so you need to rma the whole kit for replacement
I removed the other 2 sticks, booted the PC, it was fine. Replaced the first stick, and it wouldn't boot. So yeah, a bit annoying!
Going to sort the RMA with Corsair tomorrow, need to take the RAM out of the PC to get all the codes.
