12pin G-power extension??
Permabanned
30 Dec 2021
Yorkshire
the 12pin that came with my gpu is only 12cm long and the plug is in the middle of my gpu so no matter how I run the cables I have 2 8pin pcie plugs going into the adapter and it just looks a bugger, can you get because I can’t fine them extensions or just a longer cable.
What psu are you using? You may be able to get a replacement cable for it.
The first time I saw those adaptors that came with cards I thought, you penny pinching gits, for the price you are charging you could have supplied a decent length cable with it. What a joke.
They are a joke and my gpu as the power plug in the middle of it was in the end it would have been on.
My pay is a seasonic, but I have found a dreaded extension on the rain forest. 2x8pin to 12pin 30cm.
