12v AC/DC Transformer
2 Sep 2006
Forest Grove, OR, 'Merica
Does anyone know where to get one for a good price? I'm looking for one to power a few fans and a watercooling setup. What kind of amperage should I be looking for if everything will be using probably 30-40 watts?
To clarify...looking for a 240v AC to 12v DC transformer!
DaveMac said:
Are you on a mission?, try here
Why not just use the PSU?
Because I have quite a lot of components and I don't feel like upgrading my PSU. :)
And i don't see why I can't be shown somewhere else if OCuk doesn't even offer the product.
DaveMac said:
The 500w PSU in your sig should handle the extra 20-30w load from a pump and a couple of fans, try this for quick check: http://extreme.outervision.com/psucalculator.jsp
Well is there any way to find out if your PSU is being stressed? I did the calculator and it goes slightly over 500 watts if I put my CPU to 3.2 ghz (allowing headroom)
I don't want to be pushing the PSU at full capacity obviously...so i figure offloading components onto a separate PSU would be a good idea.
BTW I will have 4 120mm fans, 1 80mm fan, 4 cold cathodes...an overclocked 7900GT, and I already have 3 hard drives, 2 in RAID 0....and a DVD burner.
Anyway the laptop adapter is a good idea i think I've found some suitable ones.
Thanks for all the help
