12v fan hub recommendations please
8 Jan 2007
Barcelona
My PC still has a load of perfectly useable 12v 3pin fans that I would like to attach to my motherboard via some sort of hub. It doesn't have to be fancy with curves for each individual fan, just a single curve for all of them.
Does a product exist that does this? Could anyone recommend a specific model? I had one before but I remember it only ran the fans at full speed which was pretty useless..
i dont think a fan header has the juice for multiple fans.
all the fan hubs ive seen are powered by the PSU... there are such fan hubs which have voltage controllers on them so they can control fans. Cant see any that can be controlled by a fan curve on the motherboard.
8-Way 3-Pin 4-Pin Micro Fan PWM Speed Controller Hub (SATA Powered)​
