12v Rail Question
14 Sep 2006
Dorset Apple Cake
I have a constant output of 12.10v running through the 12v Rail when idle.
When I start gaming or encoding the rail lowers down to 12.3v.
Is this normal of a PSU to do this?
12.10 (12.1) is lower than 12.30 (12.3) so if rails go up when on load thats good, better than lowering, a Meter is only real way to get correct volts, read at idle then on load, run 3d mark and then prime etc so you test all 3 rails.
The ATX specs allow for a 5% tolerance in the 12v rails, therefore as long as the value is between 11.4 & 12.6 volts, you are fine (although figures right at the limits are clearly undesirable).
