Ok just a simple question really.
I have the Truepower 2.0 550W PSU that came with my case. Now this has gotten excellent reviews everywhere I've looked and neoseekers review included a test that showed the 12V voltage level as 12.16V on idle and 12.15V on load. Now I just installed SensorsView and this shows my 12V voltage as 11.4V. This is completely constant and I haven't seen it change through several reboots.
When I check in BIOS my 12V is shown as 12.08 or something close to that. What I am wondering is could my poor motherboard cause the lower voltage levels? This may not be possible as the motherboard never comes in to the circuit between the PSU and the components. Perhaps it is simply a sensor error with the motherboard?
What I am wondering is could me cable setup be causing this low voltage level? The PSU has a "Fan only" cable that I have my 120mm and 2x80mm case fans attached to. This doesn't supply enough power to the fans to have them running full and they only seem to run at half speed like that. That's perfect for me though as it sounds like a vacuum with them all on full even if it does drop CPU temps by 5C.
Would this be affecting the 12V rail voltage? I also have a small PCI slot extractor fan attached to the cable that feeds the AGP graphics card. Would this be causing problems?
I have 3 PATA hdds and 1 DVD drive that all run off the other cable line. Would the amount of devices on that line affect the voltage levels?
And possibly most importantly could these relatively low voltage levels on the 12V rail be causing problems? I have some minor stability issues such as occasional stuttering but I put that down to my poor Asrock motherboard.
