Hi,
My Asus motherboard has a 4 pin rgb header, and the case that I have fitted it in is the Antec Avenger. The case comes with lighting already fixed but obviously I have run into slight problem where the case is pre fitted with argb fans and lighting. Is there a way to get these lights working? If needs be I could go down the route of replacing the fans with RGB but thought I'd ask to see if there are any solutions?
Thanks in advance.
Thanks in advance.
