13.2 idle clocks
Permabanned
20 Oct 2012
Anyone else having higher then normal idle clocks with these drivers?
My core can range from 800-max and my memory is always maxe.
Voltage is up 0.1 and temps are upto 12C hotter when idle.
Idle clocks are supposed to be 150/300 so its a massive difference.
Fixed it, seems i clicked some boxes in DVI settings in CCC that makes the card do this.
Well im happy ive sorted it, reinstalling CCC does not put it back to defaults which is kinda dumb :\
